Internet Link Loadbalancing
cisco.kid111
Community Member
Hello Experts
Can we loadbalance Two Internet link terminating on a single cisco router or do we need a loadbalancer like F5 Link Controller.
Cisco Kid
7 Replies 7
  If you can go for F5, you should. If you can't,please check out this link,http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080950834.shtml
HTH,
Toshi
Toshi thank for the hyper link. F5 is expensive compare to cisco
can we pass http traffic on link#1 and VPN Traffic on Link#2. If one of the link fails all traffic should be routed through the other link and as the link is up again all traffic should float as initially set
Cisco Kid
    Yes you can.
    You may use static routes with different AD and IP SLA to accomplish those tasks.  Site-To-Site VPN?
    You may use policy based-routing to controll data plane as well.
HTH,
Toshi
Nice to hear its possible.
Plz share Hyper Link of sample config with similar requirement or close to it,  i was unlucky in finding on cisco site
Cisco Kid
Cisco Kid,
        You may try to search it from this forum. But you need to know how it works. Just write it down. Try to find/list features you want to accomplish those tasks. And then test and verify.
HTH,
Toshi
Hi there,
This is a tricky question and I think we need to know a bit more about your setup. Let me split this up into two separate questions.
1) is link one and link 2 with the same ISP or different?
2) Do you use BGP to advertise an block to the ISP or do you use addresses provided by the ISP/'s ?
Jesse
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
Have you considered OER/PfR (assuming your platforms support it)?
