Internet Speed Limit
qasimkhans8
Level 2
Level 2
I have setup traffic shaping to limit the internet bandwidth on 3 vlans (subnets), it is working but it is also limiting these 3 Vlans LAN bandwidth,
like, i setup 10Mbps internet limit which is working fine, it is also limiting 1G Lan bandwidth to 10Mbps. Please help.
following is my config.
class-map match-all Bandwidth
 match access-group name Internet-Bandwidth
policy-map Upload
 class Bandwidth
  police 10000000 conform-action transmit  exceed-action drop
policy-map Download
 class Bandwidth
  shape average 10000000
interface GigabitEthernet0/0.7
 description Voice-Vlan
 encapsulation dot1Q 7
 ip address 192.168.7.3 255.255.255.0
service-policy output Download
interface GigabitEthernet0/0.8
 description IT-Vlan
 encapsulation dot1Q 8
 ip address 192.168.8.3 255.255.255.0
interface GigabitEthernet0/0.9
 description Reg-Vlan
 encapsulation dot1Q 9
 ip address 192.168.9.3 255.255.255.0
ip access-list extended Internet-Bandwidth
 permit ip 192.168.7.0 0.0.0.255 any
 permit ip 192.168.8.0 0.0.0.255 any
 permit ip 192.168.9.0 0.0.0.255 any
 permit ip any 192.168.7.0 0.0.0.255
 permit ip any 192.168.8.0 0.0.0.255
 permit ip any 192.168.9.0 0.0.0.255
14 Replies 14
Philip D'Ath
Meraki Community All-Star
Rather than applying it on the ingress VLANs, apply it on the egress VLAN pointing towards the Internet.
Otherwise change the access list to deny shaping for traffic heading towards your private IP addresses.
 deny ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
Philip D'Ath
In fact you could probably simplify the access list down to (which means shape everything not going to and from an internal IP address):
 permit ip any any
Thanks Giuseppe and Philip, your both suggestion worked, but i analyzed that when i apply shaping on sub-internet-face (int gig 0/0.8) and i try to copy some data from other vlan server, my Lan speed downgrades, like a 1.15GB file copies around 360Mbps to 390Mbps with shaping. if i remove it from sub-internet-face (int gig 0/0.8) same file copies 700Mbps to 750Mpbs. i think shaping is till effecting Lan bandwidth.....
Philip D'Ath
What platform is this being done on?
Cisco IOS Software, 3800 Software (C3845-ADVENTERPRISEK9-M), Version 15.1(4)M8, RELEASE SOFTWARE (fc2)
Philip D'Ath
Hmm.  I suspect we might be maxing out the CPU.  When you do the file copy does the CPU on the router hit 100%?  What does it get up to?
Have you got CEF enabled?
Yes Router CPU goes to 100%, i see "ip cef" in my running config.
Philip D'Ath
The short answer is your platform does not have enough grunt to do PBR at these speeds.
You should do PBR on the circuit heading towards the Internet instead.  If you don't have such a layer 3 interface then you may need to create one.
actually my main goal is to restrict the internal user to 10Mbps link, and setup VOIP  QoS with remote office over the VPN. i have setup PBR. following is my config.
track 10 ip sla 1 reachability
delay down 1 up 1
track 20 ip sla 2 reachability
delay down 1 up 1
interface GigabitEthernet0/0.10
description Servers-&-Switches-Vlan
encapsulation dot1Q 10
ip address 192.168.10.3 255.255.255.0
no ip proxy-arp
ip nat inside
ip virtual-reassembly in
ip policy route-map PBR
interface FastEthernet0/0/1
description "Fiber Link 30Mbps"
ip address 50.x.x.x 255.255.255.248
ip nat outside
duplex auto
speed 100
interface FastEthernet0/1/0
description "Cable Link 12Mbps"
ip address 162.x.x.x 255.255.255.224
ip nat outside
duplex auto
speed auto
ip nat inside source route-map ISP1 interface FastEthernet0/0/1 overload
ip nat inside source route-map ISP2 interface FastEthernet0/1/0 overload
ip access-list extended acl_internet
deny ip 192.168.0.0 0.0.255.255 10.10.10.0 0.0.0.255
permit ip 192.168.0.0 0.0.255.255 any
ip access-list extended acl_natisp1
ip access-list extended acl_natisp2
ip sla 1
icmp-echo 50.x.x.x
threshold 500
timeout 500
frequency 1
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 162.x.x.x
threshold 500
timeout 500
frequency 1
ip sla schedule 2 life forever start-time now
route-map PBR permit 10
match ip address acl_natisp1
set ip next-hop verify-availability 50.x.x.x 1 track 10
route-map PBR permit 20
match ip address acl_natisp2
set ip next-hop verify-availability 162.x.x.x 2 track 20
route-map ISP2 permit 20
match ip address acl_internet
match interface FastEthernet0/1/0
route-map ISP1 permit 10
match interface FastEthernet0/0/1
Philip D'Ath
If you actually have a Gigabit Internet circuit then the hardware you have is not going to do meet your new requirements.
Ideally you want a layer 3 switch to route between the internal VLANs.  This can do it at line rate.
Then use something like a Cisco 4451 to do the Internet circuit and PBR.  You'll want the HSEC and probably the AppX licence as well.
i have Fastethernet for Internet and Gigabit for Intranet (Vlans) on router. I have WS-3560G as core switch, can i do shaping on core switch and VOIP QoS on router?
Philip D'Ath
This should make it easy.  Do all the routing for the VLANs on the 3560.  Don't do it on the router.
Use the router only for the Internet circuit, and do the shaping on the port to the Internet.
hmm, i have to think about it, it is critical production environment. any suggestion how to move Vlans from router to switch? and any recommended stackable switch to replace 3560.
i wanted to update you, if i remove shaping and copy data from other vlan then router CPU goes to 90%. it is normal? or there is something wrong with IOS?
Philip D'Ath
Cisco 3850's are great stackable switches.
The current 3845 you are using is struggling to keep up with the laod you are already giving it.  Yes I could believe it running at 90% CPU load based on what you have said.
The design isn't correct.  The VLANs should really be routed on a L3 switch, not the router.
