Internet Speed Testing
Alex Pfeil
Level 10
Level 10
Is there a replacement for TTCP on the cisco 4000 series routers? I used to be able to complete some throughput tests using ttcp and I am no longer able to do that.  Does anybody have a different solution for testing between two routers or networks through the internet.  We did not want to use a speedtest website.
Joseph W. Doherty
You should be able to find stand-alone TTCP and/or other bandwidth test packages. However, those will likely require some other host rather than the router itself.
Yes, I can do the iPerf or jPerf from a computer. I was just looking to see if there is a hidden command like ttcp.
TTCP is the only hidden command, for bandwidth testing, that I'm aware of. Even then, it's not found in all IOS images.
Hello
You can probe the end-to end connection via ip sla, this would give you a good indication of the RTT of a certain protocol if applicable.
R2
conf t
ip sla responder
R1 -
ip sla 10
tcp-connect 2.2.2.2 23
timeout 500
frequency 2
 or
udp-echo 2.2.2.2  67
frequency 5
     or
icmp-echo 2.2.2.2 source-ip 1.1.1.1
timeout 1000
frequency 5
ip sla schedule 10 life forever start-time now
sh ip sla statistics | be RTT
Kind Regards
Paul
