IOS downgrade issue
CSCO11638397
Please explain me while I try to downgrade ios ver "c880data-universalk9-mz.151-4.M4.bin"  to "c880data-universalk9-mz.150-1.M.bin" giving error msg wrong ios image and going to rommon mode. is that possible to downgrade cisco 887 router?
8 Replies 8
CSCO11638397
any idea?
Mohamed,
I cannot say this with 100% certainty but usually, Cisco devices allow to downgrade their IOS. Please post the complete transcript of the failed boot attempt. Also add the output of the dir flash: command from the ROMMON. Thanks!
Best regards,
Peter
Leo Laohoo
Post the entire boot up sequence. The IOS you want to run could be corrupted.
aotholland
Level 3
Level 3
I have also the same issue.
Here the outputs of 887VA
rommon 10 > dir flash:
Directory of flash:
2      28518884  -rw-     c880data-universalk9-mz.150-1.M7.bin
rommon 11 > boot flash:c880data-universalk9-mz.150-1.M7.bin
program load complete, entry point: 0x80020000, size: 0x1b32844
Self decompressing the image : ###############################################################################################################################
Wrong IOS image for the router
System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
C880 platform with 262144 Kbytes of main memory
Readonly ROMMON initialized
Self decompressing the image : ############################################################################################################################################################################################################################################################# [OK]
rommon 1 >
I know why you're getting the "Wrong IOS image for the router".
887VA does NOT support IOS version 15.0(1).  The lowest IOS you can use for a 887VA is 15.1(3)T or 15.1(4)M.
Thank you so much Leolaohoo.
i have copied from tftp c880data-universalk9-mz.151-2.T1
It works now . Thanks again.
Can you please mark this thread as "Answered"?
It's not my thread, unfortunately i cant mark. But i have voted
