IOS require
stephtchoko
Level 3
Level 3
Please which ios version is required to implement vrrp on interface cable on CMTS (UBR 7111) and on ethernet interface of 3600 router ?
Best regards.
mchin345
Level 6
Level 6
I guess any IOS in the 12 dot series should support Virtual Router redundancy protocol. To know if your IOS supports the VRRP feature use the Feature navigator tool in the Cisco website and enter your current IOS. It will then lists all the features that are supported for that IOS.
