IOS upgrade on ISR 4321 - defaulting to same IOS
vishreekhaye
I'm having some trouble upgrading the IOS on a cisco 4321 ISR.
I can see my New IOS in the directory and I have verified the IOS. (verify x)
the conf reg is 0x2102 and my boot system flash points to the new IOS. (Boot System Flash: xxx)
however after reboot it doesn't pick up the new IOS. It remains on the current IOS which I am trying to upgrade.
The images are stored on the flash (within the same path)
im doing this remotely so I do not have console access
I suppose one of my options is to delete the existing IOS and reboot? if it is an option I think its a bit risky
please can someone help me! my change window is almost up
thanks guys
7 Replies 7
Tricky...the only thing I can think of is that there is a typo in what you have configured in your boot statement. Make sure it matches exactly what is in your flash...including small and large caps, punctuation, etc...
Thanks gpauwen,
back in the office now after an embarrassing failed change. I checked, rechecked and then rechecked again for typos - I'm 100% sure its not a typo.
going to do some digging now.
Odd indeed, and quite annoying I can imagine. I am trying to find what else could be the reason as well...
Cheers GP
Here's some output - just information based stuff...
check out the attachment for more output
#sh ver
Cisco IOS XE Software, Version 03.13.02.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.4(3)S2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri 30-Jan-15 15:19 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
uptime is 1 day, 55 minutes
Uptime for this control processor is 1 day, 56 minutes
System returned to ROM by reload at 12:48:23 BST Sun Oct 16 2016
System restarted at 12:52:19 BST Sun Oct 16 2016
System image file is "bootflash:/isr4300-universalk9.03.13.02.S.154-3.S2-ext.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appx appxk9 Permanent appxk9
uc None None None
security securityk9 Permanent securityk9
ipbase ipbasek9 Permanent ipbasek9
cisco ISR4321/K9 (1RU) processor with 1687596K/6147K bytes of memory.
Processor board
x Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3223551K bytes of flash memory at bootflash:.
use the following boot statement:
boot systen bootflash:/isr4300...
almost...
boot system flash bootflash:/isr4300....
this is what worked for me
Hold on.  The "verify" command is not correct.
The correct command to compare the MD5 hash value is:  verify /md5 isr4300-bootflash:/universalk9.03.13.06.S.154-3.S6-ext.SPA.bin 41d5b39070c27c0494864de4611fe0d8
Another thing, if you want us to help, DO NOT EDIT THE OUTPUT of the command.  There is nothing "secret" about the output of an MD5 Checksum.  :P
