IP address design question
Kevin Melton
Level 2
Level 2
I am tasked with revamping an IP address scheme for a company that has a hodge podge of arbitrarily picked network addresses in place.
The network itself consists of 4 WAN locations. The largest of the WAN sides needs to have 15 networks with 170 hosts.
I have proposed the following solution to re-address the network:
Notes about IP address restructure
Glen Allen will use a /20 network boundary. The available networks in this boundary will be networks 192.168.0.0 to networks 192.168.15.0.
Louisa will have a /20 network boundary. The available networks in this boundary will be networks 192.168.16.0 to 192.168.31.0.
Marsh Run will have a /21 network boundary. The available networks in this boundary will be networks 192.168.32.0 to 192.168.39.0.
Rock Springs will have a /21 network boundary. The available networks in this boundary will be networks 192.168.40.0 to 192.168.47.0.
What I want to know is:
Will I still be able to use Class C masking within for each network number (ex. 192.168.1.0/24, 192.168.2.0/24, etc.) and then still be able to summarize at the WAN routers using the CIDR as in my proposal above?
Jon Marshall
Kevin
"Will I still be able to use Class C masking within for each network number (ex. 192.168.1.0/24, 192.168.2.0/24, etc.) and then still be able to summarize at the WAN routers using the CIDR as in my proposal above?"
Yes, no problem with that. Summarise out to the WAN and then once traffic reaches the correct location the more specific routes will route to the right place.
Jon
Giuseppe Larosa
Hello Kevin,
Yes, it is enough to use a modern classless routing protocol so if you don't use RIPv1 or IGRP you are fine.
Hope to help
Giuseppe
I was reading some documentaton today that said
"Each /8 network supports a maximum of 224 -2 (16,777,214) hosts per network".
Where does the 224 -2 come from?
"Where does the 224 -2 come from?"
Every IP address is 32 bit and have 2 parts network and host. /8 is a A class network and there are 8 network bits and 24 host bits. So A class network have 2 ^24 -2 host (We are subtracting 2 because first address is network & last is broadcast address)
8.0.0.0/8 here
8.0.0.0 is network address
Host are from 8.0.0.1-8.255.255.254
(2nd octed can have 256 options, similarly 3rd and 4th octet hence 256*256*256=16,777,216 -2 host)
8.255.255.255 is broadcast address.
