ip forward-protocol question
bellocarico
Level 4
Level 4
When I use the ip helper-address it enables by default the forwarding few protocols.
I would like to disable the onw I don;t want + enable other not included in the original config.
How can I see these?
I can find any show command telling me what protocols are already forwarded...
I know I can find them on the Cisco doc cd, but I'm wondering if there is any other way to verify what I'm doing.
Thanks to read!
5 Replies 5
devang_etcom
Level 11
Level 11
hi,,,
ip helper address
this comand sets the helper address to address. The helper address is the ip address of the host that can answer the UDP requests from other hosts. There router sees the requests broadcast on LAN interface and forwards them to the helper address(its actully generate the unicast packet as router not allow to pass the broadcast). A helper is perticularly useful for the DHCP request... the helper address command forwards packets for the BOOTP, DHCP,DNS,TFTP,TACACS, TIME and NetBIOS name...
in short it will convert the broadcast request for server in to unicast...
ip forward protocol
this command is allow you to forward any additional UDP ports that you want to forwarded automatically to the thelper IP address...
you can use the show run command... in which you will find the services which are configure by your self using the above both the commands...
you can disable it just by adding "no" in front of the command syntex...like no ip helper-address a.b.c.d
hope this help you
rate this post if it helps
regards
Devang
Devang has correctly identified the ip helper-address command as the command that takes certain UDP broadcasts and propagates a unicast (or possibly a directed broadcast) packet and the ip forward-protocol command as the command that can control what additional UDP broadcasts will be forwarded. It may not be obvious in his response that the ip forward-protocol command can also be used to disable forwarding of the standard protocols. For example you might want to forward DHCP and DNS but not the TFTP packets. You could achieve this by using the command:
no ip forward-protocol udp tftp
Rick
Rick
minumathur
Level 5
Level 5
I think, you can try " show ip nbar port-map " command, this will give you list of tcp and udp ports
Please rate this post.
-minu mathur
when you use ip helpe address method, then following UDP ports are by defaul open
1) TFTP-69
2) DNS-53
3) Time-37
4) Netbios name services-137
5)Netbious datagram services-138
6)BOOTP server-67
7)Bootp client-68
😎 Tacacs-49
Any show command telling me what protocol are forwarded?
I know I can take the initial list (enabled by the ip helper-address, take off the one I've used the no forward-protocol for and figure out the answer...
But is there any "decent" way to double check what I'm doing?
Thanks! 🙂
Stefano
I do not know of any command which will show what ports are being forwarded.
Rick
Rick
