ip sla not work
andrebiliati
Gentlemen,
I have cisco 2911 with IOS-universalK9 mz.SPA.150.1.T, but that does not accept the ip sla monitor commands XX, XX or rtr ip sla XX.
How active these commands in IOS or what you belong to?
Tks
Andre E Biliati
John Blakley
You're going to need a different IOS version. The Universal IOS is licensed based off of what features you want. You'll need , at minimum, the data version and not the base version. If you do a "sh ver" on your router, you'll notice a table of features. If they say none by the item in the "Technology" column, then your IOS doesn't support those features. So, in the data row, you should have "datak9  Permanent  datak9". If you have none in all 3, then you need an upgrade.
HTH,
John
HTH, John *** Please rate all useful posts ***
