IP Source Routing
dacruzer1
Level 3
Level 3
Can anyone help me about "IP Source Routing" and should it be disabled or enable on the router?
Thanks in advance.
Alfred
Giuseppe Larosa
Hello Alfred,
for security reasons it is recommended  to disable it as when it is enabled it can cause traffic to be diverted.
Hope to help
Giuseppe
Hi Giussepe,
Thanks for the reply, I will definitely disable ip source routing.
Alfred
