IPv6 and Switch compatibility
edwardsjj
Level 3
Level 3
Does anyone know if there is a conflict with 2950's switches running IPv6? Thank you.
Collin Clark
Looks like it's not officially supported. From the command reference on cisco.com:
"Layer 3 IP version 6 (IPv6) packets are treated as non-IP packets."
http://cisco.com/en/US/products/hw/switches/ps628/products_command_reference_chapter09186a00801cde6f.html
Looking at the switch matrix it looks like the 3560's are the lowest model that supports IPv6.
http://cisco.com/en/US/products/hw/switches/products_category_buyers_guide.html
HTH and please rate.
I don't see any issue to pass IPv6 traffic through the 2950. The issue is if you want to manage the 2950 via IPv6 as it is not supported.
Hope this helps,
