IPV6 can't ping
CthulhuSamurai
Working on my CCNA and studying IPV6.  In the attached file is the network I am working on.  I can not ping across router c, so A and B can't ping D or E, and vice versa.  This comes from Lammle's CCNA book page 574.  Any help would be greatly appreciated,
I added a default route to all 4 routers, as well as static IPv6 addresses to the interfaces, which establishes full connectivity.
What are the requirements according to the book ?
Attached is the revised file (I saved it in version 7.3).
The lab in the book just said set it up the way it was and it should work, that's all.  Thank you for your help.
