IPv6 Implementation
Ed Willson
Level 3
Level 3
I just deployed Microsofts direct access. Clients can get in no sweat, but with no internal v6 infrastructure we can't talk out to the clients.
So I'm going to get a couple thousand /64 addresses.
At this point we have a single internet connection, all of the branches are connected with mpls links.
It will be fairly easy to get all the addresses pointed to the single head end. But what happens when I get approval for a second internet connection? Will the ISP use anycast to advertise both paths? I'm pretty lost here.
Philip D'Ath
Meraki Community All-Star
Ideally the branches will be automatically and dynamically configured using something like DHCP prefix delegation.
http://www.cisco.com/c/en/us/support/docs/ip/ip-version-6-ipv6/113141-DHCPv6-00.html
It is unlikely one provider will advertise space belonging to another provider.
It is common for IPv6 machines to have multiple IPv6 addresses at the same time, and in your case, if you had two provider IPv6 address spaces then machines would end up with an IPv6 address from each provider.
Philip D'Ath
Thanks. I came to the conclusion we need to get the addresses from ARIN and peer with the ISP.
