ipv6 ping test
kishorecisco
hi guys i have configured ipv6 in my packet tracer 5.3.
But i'm not able to ping between the configured routers
Didier1966
Level 5
Level 5
Can you be a litle bit more specific.
Are you PINGING in IOS ?
ping ipv6 ipv6-address [data hex-data-pattern | repeat repeat-count | size datagram-size | source [async | bvi | ctunnel | dialer | ethernet | fastEthernet |gigabitEthernet | loopback | mfr | multilink | null | port-channel | tunnel | virtual-template | source-address | xtagatm] | timeout seconds | verbose]
Or on your PC or MAC TERMINAL ?
PING6
What is your IOS version ?
http://www.cisco.com/en/US/docs/ios/ipv6/configuration/guide/ip6-roadmap.html
http://www.cisco.com/en/US/docs/ios/ipv6/command/reference/ipv6_10.html#wp2541862
http://ipv6int.net/systems/cisco_ios_router-ipv6.html
I hope this information will help you , and helped me
Best Regards,
Didier.
Actually my packet tracer which 5.3v supports configuration of IPv6, but does not support when i use the command to ping.
Ping shows only ipv4 option not ipv6 option.
Actually the command ping ipv6 is not supported in packet tracer v5.3
but it also to configure ipv6 configurations
cadet alain
show us your config and tell us what ping is not working.
Regards.
