IPv6 question
John Blakley
All,
I have a question about how IPv6 is in relation to IPv4. How can I tell, or is it even necessary, to what subnet an IPv6 address belongs to?
For example:
I know that 192.168.1.0 and 192.168.2.0 are different subnets.
I can't find in any documentation that I've read that this type of concept exists in IPv6. I've set up v6 on a couple of routers in GNS3, and I was able to ping across the link with no issues. I set up link-local addresses with autoconfigure (FE08::0001:0002:0003). I noticed that the only difference between the two routers were the ":001". It was on R1 as :001 and R2 was :002. Okay, I assume that's the subnet (because the numbers after I believed to be the host). I changed it to something totally off the wall like :CA04, and I was still able to ping from R2.
Does anyone have experience with v6 yet?
thanks,
John
HTH, John *** Please rate all useful posts ***
Giuseppe Larosa
Hello John,
ipv6 link local are addresses that conform to EUI-64.
the subnet is FE80:0000:0000:0000/64
what ever you see is in the host portion so it can be different I guess you have it on serial interfaces.
If you enable ipv6 on a LAN interface you see FE80::/64 + a modified version of the lan MAC address (indeed called EUI-64).
for this reason link local are not routable by definition: it is always the same subnet everywhere but it is very useful for a lot of tasks: neighbor discovery, routing protocols adjacencies and so on.
So you can still ping because you have only changed the host portion of the link local address.
see
http://www.cisco.com/en/US/docs/ios/ipv6/configuration/guide/ip6-addrg_bsc_con.html#wp1038809
Hope to help
Giuseppe
Giuseppe Larosa
Hello John,
see
Hope to help
Giuseppe
Giuseppe,
Thanks for the link!
John
