IPVPN Bandwidth - Check
saquib.tandel
Level 7
Level 7
Hi Guys
Location-A is connected to Location-B over Service_Provider MPLS Cloud, we requested 50Mbps Bandwidth for each Location.
normal ping from location_A to location_B is around 5ms but file copy from PC of location_A to PC of location_B is not very bad
how do I check if the provider is really giving 50Mbps Bandwidth
Do share your feedback
cheers
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Use a traffic generator to see how much throughput you can obtain.
Regarding poor file copying performance, much can impact that, including network protocols being used.  For example, older TCP stacks don't quickly (by default) transfer across high bandwidth links with high latency.
Adeel Hasany
Community Member
As Joseph advised a traffic generator would do the job... Also if you have access to the router you can also check the bandwidth .. by the way Ipref and prtg are your good friends....
. https://iperf.fr/
Ta
Ad
