is static routing supported with dmvpn
aoshea
Dear Support,
Probably a quick yes/no answer required here !
is it possible to configure dmvpn to use just static routes rather than using say eigrp ?
even though it is going to dmvpn I only require a hub to spoke (phase1) communication, there is one hub a three spoke sites.
any useful url's would be helpful.
thanks in advance,
regards, Adrian.
thisisshanky
Level 11
Level 11
You dont need EIGRP or a routing protocol as long as you dont plan to use dual hubs. Static routes should work fine. Just a nightmare to manage it.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
