Is there a command to block output of show ip arp in Nexus7000?
wfqk
Level 5
Level 5
Hi We have a Nexus7000. but it cannot have any output of show ip arp in Nexus7000. I think that there is a command there to block it. Any one knows what it is? or what can cause this issue? I mean there are no any output when using the command--show ip arp in Nexus7000. Thank you
Vinit Jain
The question would be, are you learning an arp entry on the N7k. Try configuring an IP on two devices connected to the N7k switch and ping the devices from each other. You may then check to see if you are seeing an arp entry or not.
what modules do you have on the switch?
--Vinit
I found it in vrf interface. Thank you
