ISR4331. L2TP IPSec VPN . Unable to access remote network
Assid
I try to provide remote VPN access to office via L2TP/IPSec with embedded Windows client. The tunnel set successfully but I cannot reach remote network. No ping of remote hosts. Seems like no routing between Virtual-Access and LAN interfaces.
sh run:
vpdn enable
vpdn-group L2TP
! Default L2TP VPDN group
description VPDN_L2TP_GROUP
accept-dialin
protocol l2tp
virtual-template 1
no l2tp tunnel authentication
ip pmtu
ip mtu adjust
license accept end user agreement
license boot level appxk9
license boot level uck9
license boot level securityk9
file privilege 0
diagnostic bootup level minimal
crypto keyring KEYRING_L2TP
pre-shared-key address 0.0.0.0 0.0.0.0 key <key>
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 2
encr aes
group 2
crypto isakmp profile L2TP
match identity address 0.0.0.0
crypto ipsec transform-set L2TP_TSET1 esp-aes 256 esp-sha-hmac
mode transport
crypto ipsec transform-set L2TP_TSET2 esp-aes esp-sha-hmac
mode transport
crypto ipsec transform-set L2TP_TSET3 esp-3des esp-sha-hmac
mode transport
crypto dynamic-map L2TP_DMAP 1000
set transform-set L2TP_TSET1 L2TP_TSET2
set isakmp-profile L2TP
set nat demux
reverse-route
crypto map CRYPTO_MAP 100 ipsec-isakmp dynamic L2TP_DMAP
interface Loopback0
ip address 192.168.168.1 255.255.255.0
interface GigabitEthernet0/0/0
description -=WAN=-
ip address X.X.X.250 255.255.255.248
no ip redirects
negotiation auto
no cdp enable
ip virtual-reassembly
interface GigabitEthernet0/0/1
description -=LAN=-
ip address 192.168.8.11 255.255.255.0
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface Service-Engine0/4/0
vrf forwarding Mgmt-intf
ip address 192.168.8.4 255.255.255.0
negotiation auto
interface Virtual-Template1
description L2TP_VIF
ip unnumbered Loopback0
peer default ip address pool L2TP_ADDR_POOL
keepalive 5
ppp authentication ms-chap-v2
ppp ipcp dns 192.168.8.33
interface Virtual-Access2
mtu 1460
ip local pool L2TP_ADDR_POOL 192.168.168.10 192.168.168.100
ip default-gateway X.X.X.249
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 X.X.X.249
Where I was wrong?
I'd appreciate your help. Thank you in advanced!
6 Replies 6
I think you are missing the NAT part. I have made some changes to your config (marked in bold):
sh run:
vpdn enable
vpdn-group L2TP
accept-dialin
protocol l2tp
virtual-template 1
ip pmtu
ip mtu adjust
file privilege 0
encr 3des
group 2
encr aes
group 2
mode transport
mode transport
mode transport
reverse-route
interface Loopback0
description -=WAN=-
ip nat outside
no ip redirects
negotiation auto
no cdp enable
description -=LAN=-
negotiation auto
no ip address
shutdown
negotiation auto
negotiation auto
ip unnumbered GigabitEthernet0/0/0
ip nat inside
keepalive 5
mtu 1460
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
--> no ip default-gateway X.X.X.249
access-list 1 permit 192.168.168.0
Thank you George,
NAT has been removed by me cause I thought that it's the reason of.
Licences features:
Feature name Enforcement Evaluation Subscription Enabled RightToUse
appxk9                 yes    yes    no    yes    yes
uck9                     yes    yes    no    yes    yes
securityk9             yes    yes    no    yes    yes
ipbasek9               no     no     no    yes    no
FoundationSuiteK9 yes   yes    no    no     yes
AdvUCSuiteK9       yes   yes    no    no     yes
cme-srst               yes   yes    no    no     yes
hseck9                  yes    no     no    no    no
throughput            yes    yes    no    yes   yes
internal_service    yes     no     no    no     no
There are some differences between NAT configuration that I set before and yours concerning to 'no ip default-gateway' command and subnet in 'access-list'.  My NAT set doesn't work with L2TP. I'll try to implement your proposal soon.
since you have a default route, you don't need the default gateway.
Curious to know if the revised config works...
Output of show license feature command you can see above. K9 lics are activated and have 'In-use' state.
I've implemented your NAT config.... but the same problem haunts me again. No access to remote subnet.
I can't ping router's LAN interface even. There is no route in Windows as I can see. If so, I can add it:
route add 192.168.8.0 mask 255.255.255.0 192.168.168.X
OK, LAN interface is accessible now, but not hosts in remote network. I checked its default-gateway and it pointed to router's LAN interface as it should be.
I have no idea why it works this way.
Also, post the output of 'show license feature'...
Reason: Switch behind Router has default gateway only. Route should be set to Router.
Cisco switch "ip default-gateway" command is default gateway for the switch only, not traffic passing through the switch.
If you would need to route traffic for the switch (cisco switch normally), you would need to add "ip route 0.0.0.0 0.0.0.0 192.168.8.11" in my case.
