Issue with HSRP
dfrane
Community Member
Hi All,
I have a problem with setting up HSRP with 2 routers and 1 L3 switch. For some reason, HSRP is failing to establish between the 2 routers. I've run debug standby on both routers and it looks like they're both sending their hello but are unable to see each other's message therefore electing themselves as "active" routers respectively. I've checked the configuration on all 3 devices prior and their connectivity, I don't seem to find any problem. I'm thinking that something is blocking the ICMP hellos from both routers. Hopefully, anyone can point out if I might've overlooked something. Thanks in advance! Please see attached file for the simple setup.
Note: I'm using GNS3 as testing.
Jon Marshall
On your switch try
no ip igmp snooping
Jon
7 Replies 7
pman
I would recommend focusing on switch configuration.
First check if the switch sees the mac of the R1 and R2 Ethernet0/0 interface with
show mac address
command.
You can see the mac of both R1 and R2 in interface Ethernet0/0 using
show interface Ethernet0/0
You may find it necessary to configure the switch interfaces that connected to R1 and R2 as switchport mode access
Additionally please post the output of
show standby brief
 command from both R1 and R2,
and
show mac address-table
 from the switch.
Thanks.
dfrane
Community Member
Both mac address of the routers are seen by the switch. I notice that R1's ARP entry on the switch is the virtual MAC of HSRP this is not true for R2. R2's ARP entry on the switch is the physical interface, although both switches are running HSRP.
Jon Marshall
On your switch try
no ip igmp snooping
Jon
Thank you very much Jon! i disabled this on the switch and ran debug and re-enabled the interface on active router participating in HSRP. they received each other's hello.
share
show interface brief
in both router and L3SW
Hello
Make sure the port speed/duplex settings are correct between rtr and switchports and you can ping between the rtrs?
ping xxxx
sh interface
Also apply the following on the switchports
switch
int x/x
description link to rtr
switchport access vlan 1 spanning-tree portfast
no shut
Kind Regards
Paul
The output of
show cdp neighbor
from all 3 devices might shed some light on this issue, particularly whether the devices see each other, and if so are they on the expected interfaces?
It might also be helpful to see the output of
show interface status
from the switch with an indication of which interfaces connect the switch to the routers.
Rick
