Issues after Dynamic NAT
alvarezedwin01
Community Member
I after implement dynamic NAT i loose connectivity. It translates but nothing goes out.
pbraithwaite1
Frequent Visitor
Frequent Visitor
What device are you using? Can you share the NAT configuration?
Hello
What are you trying to achieve, It looks like your advertising the internal network 10.1.0.0/24 from rtr0 via ospf so why do you want to NAT that subnet, I would say if you want to use nat then this subnet should be advertised externally
However saying with NAT enabled on RTR0 I cannot reach the networks residing in RTR2 sourced from the the egress interface of RTR1 and you should be able to even with NAT applied, so I would say this is a quirk in the PT software which is not good at the best of times to simulate networks.
Kind Regards
Paul
