Keeps returning "Request Timeout"
PandaTV
So I'm creating a project which will have 3 servers, 3 routers, 21 pc and will be divided into 3 networks. Each servers will have different jobs to do. One will be holding the DNS, the other will hold HTTP, and last will be SMTP/POP3. I've done setting up their address including the 21 pcs and their respective network addresses. Whenever I ping network 1 to the DNS and other servers, it returns without any problem, but the network 2 and 3 keeps return "Request Timeout". I've done the same procedure as I had done in network 1, the network 2 and 3 keeps return request timeout. I've also set the email for each pc, only the network 1 has successfully done the job of sending and receiving the emails. Here's the pkt file.
16 Replies 16
keep in mind that Packet Tracer is a very good tool for learning, but you are not dealing with 'real' and full IOS versions, but rather with a subset that alllows you to perform certain tasks. There are free simulators available that give you full access to a working IOS, such as GNS3; if you are interested, have a look at the link below:
https://gns3.com/
Thanks! I'll definitely look unto to it!
