Lan can't ping wan
mattmacnish
I'm setting up an 1841 as a basic router for now and I cant get it to work.
Config
Current configuration : 1608 bytes
! Last configuration change at 00:29:28 UTC Thu Jan 1 1970 by pcl
version 15.0
service password-encryption
hostname PCL-GW1
boot-start-marker
boot-end-marker
enable secret 5 $1$J/bR$l/tjxfPKDU0GG5Q8WIY6v1
enable password 7 142313000956072A3C
aaa new-model
aaa authentication login local_auth local
aaa session-id common
dot11 syslog
ip source-route
ip cef
ip domain name pcl.net
no ipv6 cef
license udi pid CISCO1841 sn FTX1120Z046
username pcl privilege 15 password 7 15260A070178062530
redundancy
ip ssh authentication-retries 5
ip ssh version 2
interface FastEthernet0/0
ip address 10.79.4.251 255.255.255.0
ip nat inside
ip virtual-reassembly
speed auto
full-duplex
no mop enabled
interface FastEthernet0/1
ip address 96.X.X.3 255.255.255.248
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool pcl-1 10.79.4.1 10.79.4.255 netmask 255.255.255.0
ip nat pool cblvision-1 96.X.X.2 96.X.X.5 netmask 255.255.255.248
ip nat inside source list 1 pool cblvision-1
ip nat outside source list 1 pool pcl-1
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1 96.56.203.1
access-list 1 permit 10.79.4.0
access-list 1 permit 10.79.4.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
password 7 133116190E5E292B33
login authentication local_auth
scheduler allocate 20000 1000
end
What am I missing?
I can ping 4.2.2.2 but when I ping 4.2.2.2 source 10.79.4.251 nothing goes through.
9 Replies 9
cadet alain
your source address is an RFC1918 ip address so not routeable on the internet so it is normal it is not working.
Regards.
Alain.
I dont need it routable "on the internet".
What is missing to get my lan to communicate with the wan?
milan.kulik
Level 10
Level 10
NAT is not applied on a traffic sent by the router itself, is it?
So 4.2.2.2 can't reply to the 10.79.4.251 source IP address.
HTH,
Milan
Isn't this it?
you've configured:
ip nat inside
But when you issue
the packet is not received on the interface FastEthernet0/0.
So NAT is not applied on the outgoing packet, the packet is sent out to the Internet with the original source IP address 10.79.4.251.
Am I clear now?
BR,
Milan
No.
So whats missing thats preventing the router from routing traffic to the wan and back?
Shouldn't
Take care of this?
My pc on my lan can access my 1841 from the lan, so the lan is communicating with the router, and the router can communicate with the wan.  But my pc can't communicate with the wan.
This is my first go around with Cisco so all I want is this to function like a simple router, allow the lan to the internet.
How about instead of
use
I've tried that as well as
ip route 0.0.0.0 0.0.0.0 96.56.203.1
Same result
OK, so far I was explaining why you can't Ping to the Internet from your router using the LAN IP address.
Now regarding access from your LAN:
Why don't you use some simple NAT configuration?
Like
ip nat inside source list 1 interface FastEthernet0/1 overload
instead of
See http://www.cisco.com/image/gif/paws/13772/12.pdf
for example configurations.
BR,
Milan
