link problem
davila_jc
I have a link with problem, the link is restarting more o less one time for hour, the hardware link is correct, the carrier (isp)check it with a loop without problem, then configured debugs in router and i give it this:
Mar 30 11:37:52 GMT: Serial0/1/0(out): Status, myseq 87, yourseen 86, DCE up
Mar 30 11:38:00 GMT: DTE idb->dte_interface = DTE
Mar 30 11:38:00 GMT: Dscc4(Serial0/1/0): DCD is down.
Mar 30 11:38:02 GMT: %LINK-3-UPDOWN: Interface Serial0/1/0, changed state to down
Mar 30 11:38:03 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0, changed state to down
Mar 30 11:38:30 GMT: DTE idb->dte_interface = DTE
Mar 30 11:38:30 GMT: Dscc4(Serial0/1/0): DCD is up.
Mar 30 11:38:32 GMT: %LINK-3-UPDOWN: Interface Serial0/1/0, changed state to up
Mar 30 11:38:32 GMT: Serial0/1/0(in): StEnq, myseq 0
Mar 30 11:38:32 GMT: Serial0/1/0(out): Status, myseq 1, yourseen 1, DCE up
Mar 30 11:38:33 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0, changed state to up
Mar 30 11:38:42 GMT: Serial0/1/0(in): StEnq, myseq 1
Mar 30 11:38:42 GMT: Serial0/1/0(out): Status, myseq 2, yourseen 2, DCE up
this is the conf:
interface Serial0/1/0
bandwidth 192
ip address 192.168.158.34 255.255.255.252
encapsulation frame-relay
load-interval 30
frame-relay traffic-shaping
frame-relay interface-dlci 505
class 384
frame-relay lmi-type ansi
frame-relay intf-type dce
6 Replies 6
pkhatri
Level 11
Level 11
The problem seems to be with LMI, not your link. Can you confirm that the device plugged in to the end is using the same type of LMI (ANSI) ?
Paresh
Is autodetect, isp say they.
Why do you have the command ' frame-relay intf-type dce' in your configuratation. Your interface should be DTE unless you are the Service provider (Telco).
Try removing the command check the status.
HTH,
Sundar
no, the isp not support dce.
That is really odd.. In fact, if the ISP does not support DCE functionality, how will LMI inform you about the DLCIs that are configured by the provider ?
I would remove the following 2 commands to see if the link comes up:
Hope that helps - pls rate the post if it does.
Paresh
This is the configuration in site telco:
PE-MEX-5#sh frame-relay pvc 505
PVC Statistics for interface Serial10/0/2:4 (Frame Relay DTE)
DLCI = 505, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial10/0/2:4.
input pkts 87257 output pkts 59476 in bytes 7105800
out bytes 4129323 dropped pkts 0 in FECN pkts 0
in BECN pkts 0 out FECN pkts 0 out BECN pkts 0
in DE pkts 0 out DE pkts 0
out bcast pkts 0 out bcast bytes 0
pvc create time 3w6d, last time pvc status changed 19:42:26
fragment type end-to-end fragment size 240
PE-MEX-5#
You believe me?
