Load balancing problem
mingchieh
Level 2
Level 2
Dear All
I had configurated four ADSL lines to implement
multi line load balancing , (four default routes)
Everything looks ok , But I can not telnet
the interface from outside unless I disable
the cef ( no ip cef ) , I do not know why
Any one can help me ?
thisisshanky
Level 11
Level 11
Can you paste the configs.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
interface GigabitEthernet0/0
description $FW_OUTSIDE$$ETH-LAN$$INTF-INFO-GE 0/0$
ip address ISP1
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip inspect DEFAULT100 in
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no cdp enable
no mop enabled
crypto map rtp
interface GigabitEthernet0/1
description $FW_INSIDE$
ip address 192.168.1.22 255.255.255.0
ip access-group sdm_gigabitethernet0/1_in_100 in
no ip unreachables
no ip proxy-arp
ip ips sdm_ips_rule in
ip ips sdm_ips_rule out
ip nat inside
no ip route-cache cef
no ip route-cache
duplex auto
speed auto
no cdp enable
no mop enabled
interface FastEthernet0/0/0
switchport access vlan 2
no cdp enable
interface FastEthernet0/0/1
switchport access vlan 3
no cdp enable
interface FastEthernet0/0/2
switchport access vlan 4
no cdp enable
interface FastEthernet0/0/3
shutdown
no cdp enable
interface Vlan1
no ip address
interface Vlan2
bandwidth 350
ip address ISP2
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
interface Vlan3
ip address ISP3
ip access-group sparqacl in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
interface Vlan4
ip address ISP4
ip access-group sparqfttb in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
crypto map rtp
ip route 0.0.0.0 0.0.0.0 isp1
ip route 0.0.0.0 0.0.0.0 isp2
ip route 0.0.0.0 0.0.0.0 isp3
ip route 0.0.0.0 0.0.0.0 isp4
Where is the rest of your config, specifically access list 100? You have an access group expression applied on the outside interface, where is the corresponding access list?
