Load Sharing - BGP
Anukalp S
Hi all,
I have two links to ISPs on one router. They are advertising default route to me. Both ISP are in different AS. I want to share load on both links. I want to configure bgp bestpath as-path multipath-relax command but my router doesnt support it. What i am seeing while configuring it is mention below.
Can anyone pls help me configuring this.
Router(config-router)#bgp bestpath ?
  compare-routerid  Compare router-id for identical EBGP paths
  cost-community    cost community
  med               MED attribute
Router#sh ver
Cisco IOS Software, 3800 Software (C3845-SPSERVICESK9-M), Version 12.4(24)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 25-Feb-09 23:14 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T10, RELEASE SOFTWARE (fc1)
blau grana
Level 7
Level 7
Hello Anukalp,
This is cisco hidden command -> bgp bestpath as-path multipath-relax
You will not see it, but you can use it.
R1(config)#
R1(config)#router bgp 100
R1(config-router)#bgp bestpath ?
  med               MED attribute
R1(config-router)#bgp bestpath as-path multipath-relax
R1(config-router)#do sh run | s bgp
router bgp 100
no synchronization
bgp log-neighbor-changes
no auto-summary
R1(config-router)#
http://wiki.nil.com/Multipath_Load_Sharing_with_two_ISPs
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
blau grana
Level 7
Level 7
Hello Anukalp,
R1(config)#
  med               MED attribute
router bgp 100
no synchronization
no auto-summary
R1(config-router)#
Best Regards
Thanks  Blau
