Loop STP
lricov011
Good afternoon,
I am presenting microcuts on my LAN, I found this log on the switch% STP-W-PORTSTATUS: e12: STP status Forwarding. I took a capture with wireshark but I can't understand what is happening.
Could you please help me interpret the capture?
Thank you
luis_cordova
Hi @lricov011 ,
I tried to download the attachment, but it has an error.
Could you share the file in .jpg and the switch settings that present the problem?
Giuseppe Larosa
Hello Iricov011,
I can confirm that the attached file cannot be opened so follow Luis suggestions and put a jpeg image of the packet capture.
This should mean the specified port has moved to STP Forwarding state, this can be a sign of a topology change occuring in your network.
Hope to help
Giuseppe
