Maxmimum port in LACP
N.ima0102
How many port can exist in LACP ?
Can I put 16 port in one Link Aggregation ?
Thanks in advance
Peter Paluch
Up to 16 ports can be added to a LACP bundle. However, at most 8 ports will be active and carry data. The remaining ports will be in standby mode, waiting to replace another active port if it fails.
Note that the limit of 8 active ports in a bundle is reasonable. If you need more than 8 ports in an EtherChannel bundle, you should instead use a higher-speed Ethernet variant.
Best regards,
Peter
