Memory issues
terrelstinnett
I am trying to upgrade my IOS on a 3550 switch.
The switch has 15MB of space total.
When I delete the current IOS it leaves only 8MB of space.
I need 10MB of space for the new image.
Where is this other space being taken up?
Can I do something to free up the space somewhere?
Switch#dir flash:
Directory of flash:/
    2  -rwx         916   Mar 1 1993 00:06:53 +00:00  vlan.dat
    3  -rwx        3790   Mar 1 1993 00:39:12 +00:00  config.text
    4  -rwx          24   Mar 1 1993 00:39:12 +00:00  private-config.text
    5  -rwx     5687963   Mar 1 1993 01:11:18 +00:00  c3550-ipbasek9-mz.122-25.SEB4.bin
    8  drwx         192   Mar 1 1993 00:04:40 +00:00  c3550-i9q3l2-mz.121-22.EA1a
15998976 bytes total (3300864 bytes free)
Accessing tftp://192.168.1.50/c3550-ipservicesk9-mz.122-44.SE6.bin...
Loading c3550-ipservicesk9-mz.122-44.SE6.bin from 192.168.1.50 (via Vlan1): !!!!!!!!!!!!!!!!
(more exclamation marks)
%Error writing flash:/c3550-ipservicesk9-mz.122-44.SE6.bin (No space left on device)
Thanks for your help guys.
swordcrowned
Level 3
Level 3
Stanley,
You have two IOS images on your switch.  One is the .bin file, and the other is in the drwx directory.  Use the "show boot" command and note down which ios is being used to boot the device.  If it is the c3550-i9q3l2-mz.121-22.EA1a, then just delete the c3550-ipbasek9-mz.122-25.SEB4.bin file.  If the boot ios is the c3550-ipbasek9-mz.122-25.SEB4.bin, then use the command "delete /force /recursive flash:c3550-i9q3l2-mz.121-22.EA1a".  That should free up enough space to load the new IOS.  After you load the new IOS, make sure you change the boot for the switch to the new IOS.  Save the config and reload.  After the reload, delete the old IOS file so you dont have this issue again in the future.
Bryan
Jason Dance
Level 4
Level 4
I believe I have answered this over in the other thread: https://supportforums.cisco.com/thread/2134297?tstart=0
Leo Laohoo
DUPLICATE POSTS.
Stanley, can I request if you refrain from making multiple posts of the same issue?
