MGX8250 firmware upgrade
sampusarkar
I have MGX8250 and recently i have inserted in VISM-8E1 card . Presently the VISM -8E1 card is in BOOT mode . I am not sure how do i burn a firmware into that . in MGX8850 setrev is the command . I have found in MGX8250 documentation in Cisco site and the command is commit sm <rev> . I have applied that but the command is not going thru . Can you please let me know the exact command .
I want to burn 002.001.000.000 image.
Arjun
a-vazquez
Level 6
Level 6
For information on burning the image kindly refer to the following URL,
http://cisco.com/en/US/products/sw/ps2346/ps1929/products_configuration_example09186a00801a42b7.shtml
switchxchange
You have to first execute the PXM install command ...
"install sm "
e.g. "install sm 1 vism_8t1e1_002.001.000.000.fw"
Then you have to execute the PXM newrev command ...
"newrev sm "
e.g. "newrev sm 1 vism_8t1e1_002.001.000.000.fw"
Finally you have to execute the PXM commit command ...
"commit sm "
e.g. "commit sm 1 vism_8t1e1_002.001.000.000.fw"
rgds
Joern
SwitchXchange
Hello Joerm ,
Thanks for the update . But the command didn't work as expected . Finally i got the
process and i am planing to apply .
The problem is MGX8250 is pretty old box and the commands diffres from MGX8850 chassis .
C:\cp vism_8t1e1_002.001.000.000.fw \FW\sm150.14.fw
install sm 14 002.001.000.000
Arjun
