Monitor WAN traffic 3750
sketterman
I have a 3750 acting as my WAN router connected to our MPLS provider via ethernet.  For a couple days my inbound bandwidth has been completely saturated at 20Mbs (the speed of my link).  I know this model of switch does not support netflow, but is there any other way to try and find out what is using all the bandwidth?  I have pretty much ruled out anything on the internet since the in/out interfaces of my firewall are not seeing much traffic.
Thanks in advance
Eugene Khabarov
Level 7
Level 7
Maybe ip accounting will help?
HTH. Please rate this post if it was helpful. If this solves your problem, please mark this post as "Correct Answer."
ro-mgi-cco
Hello Sketterman
A way to see what traffic of a 3750 , use a Packet Sniffer and "Monitor" the traffic to the sniffer port.
You can use a SPAN configuration :
(config)monitor session XX source interface Fa/Gi/XX/0/XX
(config)monitor session XX destination interface Fa/Gi/XX/0/XX
You can use Colasoft Capsa or WireShark to do a graphic based on ports or ip's
Cheers
MSYS
Also a variant...
