Monitoring IP Traffic
rasoftware
I have a link which is showing very high utilization.
Is there a way I can monitor which host/IP this is coming from? I seem to remember doing something with IP accounting but im not sure.
pkhatri
Level 11
Level 11
The following thread has some ideas that myself and some other posters contributed to regarding this very thing:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=WAN%2C%20Routing%20and%20Switching&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1dda6899
Hope that helps - pls rate the post if it does.
Paresh
Thanks for that most helpful.
A couple of things I noticed:
Dialer1 is up, line protocol is up (spoofing)
reliability 255/255, txload 1/255, rxload 61/255
When I implement IP account on FE0/1 I get
Source Destination Packets Bytes
205.205.36.178 10.0.129.29 55 73398
84.45.224.23 10.0.129.6 11 11449
84.45.224.14 10.0.129.31 80 109545
I have done this by implementing it on the interface FE0/1
ip accounting output-packets
ip accounting precedence input
ip accounting precedence output
I guess that is showing whats being downloaded, is there a way I can see whats coming from each LAN address as the source.
When I look at usage graph in SDM it 50-100% always of 2MB SDSL but I can't see where all this traffic originates.
Using ip flow top talkers this also doesnt show any "outstanding" amount of traffic which could be causing this.
I will advice you to enable netflow. On the LAN interface add the config -
ip route-cache flow
Then use
sh ip cache flow
to display the flows that are entering into the router.
Netflow is able to give a lot more information than ip accounting. It gives the source and destination ip addresses, the source and destination interface, the soruce and destination ports, the ip protocol number and the number of packets in the flow. Note that the ports number and the ip protocol numbers are written in hexadecimal. Also, Netflow is an ingress technology, so the flows displayed are the ones entering the interface only.
