MPLS backup using VPN
wildchief
Dear  Forum,
I wonder if someone might be able to assist me with a question I have.
I have a head office which connects to remote offices using MPLS.  This is a managed service and I do not have write access to these routers (cisco 1800) series.  At each of the sites, head office and remote I also have an internet leased line and a Cisco ASA.  This provides me with local access to the internet for eac of the sites and it gives me the opportunity to create VPN between the sites as a back up connection in the event of the MPLS line being unavailable.
However can I create a failover so that no manual intervention is required?  This Cisco ASA is the default gateway for the  hosts at each of the sites so I can use this to make routing decisions
I have attached a simple diagram of my environment
Thank you for reading and thank you for any suggestions
David
milan.kulik
Level 10
Level 10
have you asked your MPLS provider for an opinion?
Some providers offer an MPLS connection with a cheap Internet  VPN backup.
If you have more than just two sites connected to the MPLS backbone, it could be a good solution for all your sites.
It's always easier to configure something with the provider cooperating.
BR,
Milan
