MPLS hardware for Multiple sites
miank
I need to connect my 4 branch offices (different geo graphical locations) with HQ as well as with each other. I have acquired 4 x 100MB MPLS Links to connect with branch offices having different subnets. Please any one can tell me that
1- What hardware i should have at my 4 x branch offices to connect with HQ?
2- What hardware should i have at my HQ to connect 4 x branch offices ?
3- What Hardware should i have to connect my 4 x branch offices with each other ?
Need answer very urgently...Thanks in advance for great help.
Thanks !
Negative - not a 3560 but a 3650.
Note there is a 3560 switch, but it is old.  So don't get those two numbers transposed by accident.
I would use a 3650/891-24X - or - a Firewall, but not both.  If you want to keep the ASA 5500s, then you can do it with just those.
But there is a lot of configuration involved.  NAT rules.  Access rules.
17 Replies 17
Philip D'Ath
The term MPLS is a bit like the term WAN, and can mean a lot of different things.
For example, it is quite possible you have actually bought a VPLS MPLS solution from your provider.  And if that it the case, it is quite likely you don't have to put in anything, as the service provider is likely to supply everything,
Another possibility is you have bought point to point layer 2 MPLS services, in which case you are going to have to buy something.
I think it is more likely to be VPLS, because you mention subnets.  VPLS is a layer 3 service, and if you had to give the provider subnets, then this is a hint.
So probably best you start this discussion with your MPLS provider and ask them what you need at each end.
Thanks Philips,
Say if its L2 MPLS, do i need Firewall at each site, if i am not behind SP firewall ?
Only if they are Internet circuits.  Are they private links, or Internet circuits?
In fact it is Ethernet Network Service (Metro Ethernet). My Provider has given me 4 x 10/100 network Interfaces. so keeping in view , what is hardware i have required at my side ?
Thanks Philip for your great help !
one quick question, whether i need both routers and switches ? also I have attached what my provider has given me. actually i am confused that what hardware i have to have ...
Thanks!
If you use layer 3 switches - then you only need a switch.  No router needed.  The reason I like the layer 3 switches is you need a switch at each site anyway, to plug in all the computers.
If you already have layer 2 only switches, then you could consider putting in a router instead.
The routers do have extra functionality, but you are unlikely to need them.
And then you get interesting options, like the 891-24X, which is a router with a 24 port Gigabit switch built in, with 8 of those ports being PoE.
I believe each site have 70 to 90 users.and if i buy Cisco layer 3 switches, so i need 2 x 48 10/100/1000 layer 3 switches with IP services for each site. right ?
Thanks !
If you are happy with with "RIP", "EIGRP Stub" or "static routing"  then you only need "IP Base".
If you have that many users, I would probably go for a stacked pair of Cisco 3850's.  You can stack 3650's, but you have to buy extra stacking modules, and after buying those you might as well as bought the higher spec 3850's.
http://www.cisco.com/c/en/us/products/switches/catalyst-3850-series-switches/models-comparison.html
Bravo !
One thing more.. if i have fiber hand-off from provider instead of copper RJ45, will i have to change switch ? secondly, i have CISCO ASA 5500 series firewalls on each site, what if i connect hand-off (fiber/copper) directly to firewall and then connect from firewall to switch ?
Thanks !
You just need a switch with a fibre module then.
You could use a firewall to terminate the connections.  You wouldn't really need anything else to do the layer 3 then.
But the layer 3 switches will be kick-arse fast ...
I guess it comes down to how much you want to spend.
Great !!!
So, conclusion is that i need Cisco 891 router OR Cisco 3560 Switches at each site to terminate hand off. (Fiber/Copper). And if need to put firewall , i can use on edge.
correct me if i wrong...
Also please see attachment Design and recommend pls.
Thanks !
and another thing that if i use 891-24x routers for terminating Metro Ethernet hands off. whether it will support 100mb WAN circuit speed ? and might be we increase from 100mb to 200mb in future.
thanks !
It will manage 100Mb/s no problems.
As long as you don't enable NAT or firewall it should do 200Mb/s easily.
