MPLS QoS Not Marking Nor Queueing
Chuan Liu
Hi All,
I have configured MPLS QoS in a 1841 PE router. F0/1, which is connected to CE, is marking the traffic; F0/0 is doing LLQ. But 'show policy-map int f0/0' shows packets matched but no marking is done for 'mpls experimental topmost X'. So I add 'set ip dscp' command. Packets are now marked with the dscp value, but still no queueing is happening in f0/0.
Here is the config:
class-map match-any mpls-5
match mpls experimental topmost 5
match ip dscp ef
class-map match-any mpls-3
match mpls experimental topmost 3
match ip dscp af31
class-map match-any iMission-Critical
description Interactive data:citrix sna telnet
match dscp af31
match access-group name Misn-critical
match ip dscp af31
class-map match-any iRealTime
description RealTime
match dscp ef
match dscp cs5
match dscp cs4
match access-group name Realtime
match ip dscp ef
match ip dscp cs5
match ip dscp cs4
policy-map TO-CORE
class mpls-5
priority 6000
class mpls-3
bandwidth 1000
random-detect
class class-default
bandwidth 3000
random-detect
policy-map 10-TO-CORE
class class-default
shape average 10000000
service-policy TO-CORE
policy-map FROM-CUSTOMER
class iRealTime
set mpls experimental topmost 5
set ip dscp ef
class iMission-Critical
set mpls experimental topmost 3
set ip dscp af31
class class-default
set mpls experimental topmost 0
set ip dscp default
'show' output is attached.
Thanks in advance.
Giuseppe Larosa
Hello Larry,
some more information is needed.
this traffic belongs to a L3 MPLS VPN ?
If not the PHP= penultimate hop popping could cause traffic sent out f0/0 to be sent out without any label.
How long is the router chain ?
Two suggestions:
what happens if:
a) you use set mpls exp instead of set mpls exp topmost
b) on interface facing core try to apply the CBWFQ policy-map directly to the interface.
Hope to help
Giuseppe
Hi Guiseppe,
Thanks for the response.
Yes, F0/1 is put in a VRF for a small site. F0/0 is facing the MPLS core. LLQ is applied directly to F0/0.
When I use 'set mpls exp' instead of 'set mpls exp topmost', I can see packets are marked on F0/1. But in the core facing policy, the 'topmost' key word cannot be removed. And, in the show output, the number of matching packets differs from the queueing number of packets as below: 130804 packets matched, but 50 are queued.
Service-policy : TO-CORE
Class-map: mpls-5 (match-any)
130804 packets, 26652361 bytes
5 minute offered rate 1000 bps, drop rate 0 bps
Match: mpls experimental topmost 5
5 minute rate 1000 bps
Match: ip dscp ef (46)
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 6000 (kbps) Burst 150000 (Bytes)
(pkts matched/bytes matched) 50/8829
(total drops/bytes drops) 0/0
Is this normal?
Thanks.
Hello Larry,
no it is not normal
I would try with CBWFQ applied directly outbound the core facing interface
Hope to help
Giuseppe
Hi Giuseppe,
Thank you. I found the link that explains the counters.
http://www.cisco.com/en/US/tech/tk543/tk760/technologies_tech_note09186a0080108e2d.shtml
thanks again.
