MPLS-TE on Multilink Interfaces
davidhuynh5
I want to run mpls-te on a multilink interface with 3 T1s (4.5Mbps).
Do I apply the commands "mpls traffic-eng tunnels" and "ip rsvp bandwidth" on the virtual multilink interface or the physical interfaces itself or both?
Thanks in advance.
Giuseppe Larosa
Hello David,
you should configure it under the only L3 object you have the multilink interface.
the same place where you would put mpls ip and so on.
Hope to help
Giuseppe
Giuseppe Larosa
Hello David,
Hope to help
Giuseppe
Thanks G.  9314 posts incredible.
