11-05-2021 03:22 AM
Hi All,
Question is relating to Multicast - ASM. I understand that initial multicast flow will be using shared tree via (RP is in forwarding path) after that it will be switched to SPT. Questions - -
* Does RP /down/outage scenario can bring down the whole multicast traffic in the network ?
Thanks !
Solved! Go to Solution.
11-05-2021 08:52 PM
Hello @ashapd ,
in ASM PIM SM existing multicast groups that have alreay switched to the source based tree SPT from the shared tree are able to keep going on.
New groups are prevented from reaching the RP so new groups are impacted.
Dense mode fallback can be used here in this case new groups will be flooded every where using PM DM.
The natural design solution for avoiding issues is the use of AnyCast RP
multiple nodes impersonate the RP address at the same time using a loopback address (different from the loop0)
MSDP is used between the nodes to exchange info about active sources SA, SA info also tells what (S,G) pairs are active.
if one node dies the IGP in use OSPF or EIGRP or IS-IS will route packets for the Anycast RP address to the nearest node advertising it in the IGP.
Hope to help
Giuseppe
11-05-2021 04:04 AM - edited 11-05-2021 04:05 AM
Hello
For the initial MC connection, the FHP/LHP rtrs need to be able to reach the RP, then SPT cutsover unless that has been disabled however I would say there still needs to be a pim rp mappng so if this is lost I would say MC traffic would be lost also.
11-05-2021 07:52 AM
Thanks for the update. I guess only new multicast flow will be impacted. The existing one should work ?>
11-05-2021 08:52 PM
Hello @ashapd ,
Hope to help
Giuseppe
