Multiple ISP connection and IP advertisement
danielkwofie
Hi All,
Have a little challenge using multiple isp internet conection.  I had ISP A which was advertising my ip block (with my ASN), i've however added ISP B, and have peered with their network (BGp) and thus they are also advertising my IP..  however, i realised that all request to my ip block from the internet goes through ISP A. but i want ISP B to be my Primary ISP  since am getting more bandwidth from them. how do i check my ip advertisement with ISP B and what do i need to do so that inbound traffic primarily traverse ISP B....
Thanx for help
Hi Daniel,
Using Multiple ISP is reference to BGP  Multihoming ,
To manipulate to advetisement in BGP you should user BGP attributes . Below are the detail .
From Inside to Outside use : Local Prep
From Outside to Inside use  : Prepend AS
In your senario if you want to user ISP B as a primiary link then you should configure AS prepend with ISP A . So over internet the route will prefered from ISP B becasue of shortest AS Path.
Please refer for sample lab for same : http://showipbgp.com/bgp-configurations/cisco.html
Chetan Kumar
http://chetanress.blogspot.com
