Multiple subnets routing
Asfandyar70754
Level 4
Level 4
Hello everyone
I want to use separate vlans for departments in my office.
So for example,
I have 2 vlan 36,37 of subnets 192.168.36.0 and 192.168.37.0, I have made 2 dhcp pools for vlans/subnets.
Users are getting IP of their respective vlans but they are not able to access internet. I think I am stuck in some routing.
So if someone can they me how should I route these 2 subnets to my gateway.
7 Replies 7
Georg Pauwen
what does the rest of the topology look like ? How did you configure the inter-Vlan routing ? Typically, a layer 3 device is doing the routing (towards the Internet) and the network address translation.
In short, we need to know what devices you have deployed. Post either a brief schematic drawing, or indicate how the devices are connected, e.g.:
ISP Modem --> Router --> Switch
Hi Paul and Georg
This is how my topology looks like right now.
ISP -> L3 Switch -> 2 L2 Switches
I have Vlans on my L3 switch.
I don't want two vlans to communicate
Hello
What type L3 switch do you have and can you confirm if you are receiving a public or non public ip address from the isp
Kind Regards
Paul
Please ignore earlier design this is the one:
ISP -> TP-Link Load balancer -> L3 Switch -> 2 L2 Switches,
On L3 switch I have private IP.
the first issue will be to get the new Vlan subnets NATted on the TP Link router. You need to add these networks to the networks that are to be translated. As for the L3 and L2 switch configuration, the setup would look like below:
L3 Switch
interface Vlan 10
ip address 192.168.10.1 255.255.255.0
interface Vlan 20
ip address 192.168.20.1 255.255.255.0
interface GigabitEthernet0/1
description Link to L2 Switch 1
switchport mode trunk
interface GigabitEthernet0/2
description Link to L2 Switch 2
L2 Switch 1
description Uplink to L3 Switch
interface FastEthernet0/1
switchport mode access
switchport access vlan 10
spanning-tree portfast
interface FastEthernet0/2
switchport access vlan 20
L2 Switch 2
Hello
so the TP link router is receiving a private ip address from the ISP which means the isp is performing nat
do you havr admin access to your TP router to add static routes and apply NAT - if yes then you are in a good position to provide internet access for your user vlans  - please confirm ?
After this the next step will be to decide how to wish to separate the vlan communication for that you have a couple of way to do this
1-routed acls on the L3 subnets
2 separate vrfs for each vlan
Kind Regards
Paul
Hello
In addition to what @Georg Pauwen  has asked, when you mention separate do you wish for those two vlans to be unable to communicate with each other?
Kind Regards
Paul
