NAT/Access list problem
michellp
Level 3
Level 3
Hello, I have a cisco 1800 which I'm trying to get nat working on. See running config and software info below. I have 1 public (internet) and I have a couple of subnets on the inside, of which one is directly connected; 192.168.1.x. My pc from where im testing is in this 192.168.1.x network and has 192.168.1.11. Now I believe I have the configuration right but It does not work as expected. Now I do have internet connectivity since I can ping 8.8.8.8 from my test pc. However no other traffic is allowed. I know that icmp works because of the permit icmp any any rule in the access list Internet_To_Lan which I added for testing purposes. Now the only way I can get it to work is when I add another rule to this same access list; 1 permit ip any host 90.95.150.85. Now this last addition to the access list is one I'm not to happy about. It sounds risky. I don't understand why it's needed. I always thought that when using natting there was no need to specify a permit rule for returning traffic. IS this assumption correct or am I completely lost here? Please help?
Software:
Cisco IOS Software, C181X Software (C181X-ADVENTERPRISEK9-M), Version 12.4(6)T, RELEASE SOFTWARE (fc1)
ROM: System Bootstrap, Version 12.3(8r)YH8, RELEASE SOFTWARE (fc2)
System image file is "flash:c181x-adventerprisek9-mz.124-6.T.bin"
Running config:
Router#sh run
Building configuration...
Current configuration : 3294 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$mwBtxxxGWcHoxxI5Trxxxqv.da.
no aaa new-model
resource policy
ip cef
ip name-server 10.41.0.1
ip name-server 10.41.0.2
ip name-server 10.42.0.100
username xxxxxxxx privilege 15 secret 5 $1$ukNP$Zxxxx8eyF.BkxxxxHdJbI.
interface FastEthernet0
description Inside Lan
ip address 192.168.0.10 255.255.255.248
ip access-group Lan_To_Internet in
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
description Outside Internet
ip address 90.95.150.85 255.255.255.248
ip access-group Internet_To_Lan in
ip nat outside
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
no ip address
interface Async1
no ip address
encapsulation slip
ip route 0.0.0.0 0.0.0.0 90.95.150.81
ip route 10.41.0.0 255.255.254.0 192.168.0.9
ip route 10.42.0.0 255.255.255.0 10.41.0.254
ip route 10.45.1.0 255.255.255.248 192.168.0.9
no ip http server
no ip http secure-server
ip nat inside source list NAT_To_Outside interface FastEthernet1 overload
ip nat inside source static tcp 192.168.0.11 21 interface FastEthernet1 21
ip nat inside source static tcp 10.41.0.5 25 interface FastEthernet1 25
ip nat inside source static tcp 10.41.0.5 587 interface FastEthernet1 587
ip nat inside source static tcp 10.41.0.5 993 interface FastEthernet1 993
ip nat inside source static tcp 10.451.0.7 3101 interface FastEthernet1 3101
ip nat inside source static tcp 10.45.1.2 50 interface FastEthernet1 50
ip nat inside source static tcp 10.45.1.2 51 interface FastEthernet1 51
ip nat inside source static tcp 10.45.1.2 500 interface FastEthernet1 500
ip nat inside source static tcp 10.45.1.2 4500 interface FastEthernet1 4500
ip nat inside source static tcp 192.168.0.11 20 interface FastEthernet1 20
ip access-list standard NAT_To_Outside
permit 10.41.0.0 0.0.1.255
permit 192.168.0.8 0.0.0.7
deny   any
ip access-list extended Internet_To_Lan
permit icmp any any
permit tcp any host 10.41.0.5 eq smtp
permit tcp any host 10.41.0.5 eq 587
permit tcp any host 10.41.0.5 eq 993
permit tcp any host 10.41.0.7 eq 3101
permit tcp any host 10.45.1.2 eq 50
permit tcp any host 10.45.1.2 eq 51
permit tcp any host 10.45.1.2 eq 500
permit tcp any host 10.45.1.2 eq 4500
permit tcp any host 192.168.0.11 eq ftp
ip access-list extended Lan_To_Internet
permit ip 10.41.0.0 0.0.1.255 any
permit ip 192.168.0.8 0.0.0.7 any
deny   ip any any
control-plane
line con 0
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
session-timeout 60
login local
length 0
line vty 5 15
session-timeout 60
login local
webvpn context Default_context
ssl authenticate verify all
no inservice
end
Router#
you have to specify the public IP as destination not the private IP.
Regards.
Alain
cadet alain
permit icmp any any
deny   ip any any
The problem is with
return traffic is dropped by the implicit deny at the end
just try this :
15 permit udp any eq 53 any
16 permit tcp any any established
110 deny ip any any log
Regards.
Alain
Hello Alain,
Thanks for your reply. This works and solves the issue from traffic going from inside to outside. Now the 2nd part is incoming traffic from the internet destined for certain ports. I tested it with FTP. So I have this rule in the same access-list, ip access-list extended Internet_To_Lan; permit tcp any host 192.168.0.11 eq ftp and the nat entry; ip nat inside source static tcp 192.168.0.11 21 interface FastEthernet1 21
Interface fa1 is the outside interface with the public ip. (I prefer not to talk in the cisco terms global, inside, outside, it's confusing) So I believe this to be correct, no? Again if I add the rule permit ip any host 90.95.150.85 it works, but without it gets filtered, see debug log:
*May 23 09:50:06.323: %SEC-6-IPACCESSLOGP: list Internet_To_Lan denied tcp 91.125.26.162(58468) -> 90.95.150.85(21), 1 packet
Why is this? Or is the ip nat config just plain wrong?
Regards.
Alain
thanks for your help Alain.
I've rated your answers.
Michell
