NAT changing IP source
guilherme
Level 3
Level 3
Hi all,
What would be the best way to configure NAT on Cisco IOS in such a way that when a packet arrives on the outside of my router, it is redirected to an internal host but changing the source IP? Does anyone have a similar IOS configuration?
Thanks in advance.
5 Replies 5
You can use ip nat outside command to translate the outside ip to an internel ip address., this will nat translate in both directions:
example:
outside global addresss - 200.200.200.2
inside local - 10.2.2.2
ip nat outside static 200.200.200.2 10.2.2.2
res
Paul
Kind Regards
Paul
Marwan ALshawi
just to add to the above post
lets say you have the folowing scenario
LAN 10.1.1.0/24----Router1-.1---192.168.1./24--.2--Router2-----10.2.2.2
and you want 10.2.2.2 to be seen by 10.1.1.0 LAN as 20.2.2.2
what you can do it
in router1
ip nat outside static 10.2.2.2 20.2.2.2
you need a static for the 20.2.2.2 to point to Router inorder for the NAT outside to work
ip route 20.2.2.2 255.255.255.255 192.168.1.2
inter x/x
ip nat inside
inter x/x  -- connected to R2
ip nat outside
hope this help
if helpful rate
What if I need to "hide" every public IP addresses from an internal host?
What I need is basically a NAT but when any public IP reaches my router's outside on port 80/tcp, I need the connection to be NATed to an internal host on the same destination port but also changing the *source* address.
for example;
LAN (192.168.1.0/24) ----> (Gi0/0 ip:192.168.1.1)Router (Gi0/1 ip:8.8.8.8) ------> WAN
Web Server ip : 192.168.1.10
you can use config below;
#conf t
(config)# int gi0/0
(config-if)#desc LAN
(config-if)#ip addr 192.168.1.1 255.255.255.0
(config-if)#ip nat inside
(config-if)#exi
(config)#int gi0/1
(config-if)#desc WAN
(config-if)#ip addr 8.8.8.8 255.255.255.252
(config-if)#ip nat outside
(config-if)#exi
(config)#access-list 10 permit 192.168.1.0 0.0.0.255
(config)#ip nat inside source list 10 int gi0/1 overload
(config)#ip nat inside source static tcp 192.168.1.10 80 int gi0/1 80
(config)#end
#wr
hth
Muammer
do you mean you have internal server with public IP and confugured internally with private IP you want to do nat for it on port tcp 80 ?
and in addition al the source IPs confign from outside has to be changed to somthing private ?
if yes you can use th ebelow example
server IP 192.168.1.1-----Fa0/0-R1--Fa0/1----internet
server public IP is 100.1.1.1
ip nat inside source static tcp 192.168.1.1 80 100.1.1.1  80
for outside soruce address to be translated to any private address lets say 10.1.1.0/24
access-list 100 permit tcp any host 100.1.1.1
ip nat pool pool1 10.1.1.1 10.1.1.254 netmask 255.255.255.0
ip nat outside source list 100 pool pool1 add-route
you need a static route fo rth edummy pravte address 10.1.1.0 point either to the exit interface or to your ISP next hope
ip aroute 10.1.1.0 255.255.255.0 interface fa0/1
or
ip route 10.1.1.0 255.255.255.0
int fa0/0
ip nat inside
int fa0/1
ip nat outside
hope this help
if helpful rate
