NAT Lab
jsblach
Hi i do have a very simple setup in
GNS3
with two VPCs and two IOUL2 switches.
One switch has the following configuration:
Spoiler
interface Ethernet0/0
switchport access vlan 123
switchport mode access
interface Ethernet1/0
no switchport
ip address 192.168.178.254 255.255.255.0
ip nat outside
interface Vlan123
ip address 192.168.0.254 255.255.255.0
ip nat inside
ip nat inside source list 1 interface Ethernet1/0 overload
access-list 1 permit 192.168.0.0 0.0.0.255
ip route 0.0.0.0 0.0.0.0 192.168.178.1
If i use ping 192.168.178.1 source vl 123 on the switch, everything works fine and i see an entry
in
sh ip nat trans
. But if i ping 192.168.178.1 from an attached vpc it doesn't work.
Where am i thinking wrong?
Thanks in advance!!!
Then dont waste your time' the IOS SWl3 image canot do
NATing.
10 Replies 10
Did you add
İp routing
To SW?
 It woud be a behavior expected IF the PC has not gateway or wrong gateway
jsblach
hi, thanks for your answers.
@MHM Cisco World  yes, and if i configure
static routing
instead of
nat
i get a reply.
@Flavio Miranda
the vpc have gateways
configured, as i said, routing works
nat
doesn't
jsblach
here i have the gns3 project attached
NATing.
jsblach
ok so you would say, that the configuration in general would be correct?
So so correct'
Your config is perfect but there is some bug in
gns3.
jsblach
but it does work in this case. why wouldn't it work with a vpc using the svi address as gateway?
You are learning and you need to sure that you config is correct'
I will apply same config you share in my lab and share reuslt.
I also have
gns3
and after weeks try solve this issue I give up and use
NSK sw
instead.
I will share lab tonight dont worry.
MHM
Hello
instead of using a
VPC node
, use a
rtr
and disable
ip routing
on that router so to make it a host device ( ip address & D/G) and test again.
Kind Regards
Paul
