NAT Problem with ISR4321
I purchased few months back ISR4321 with xDSL modem (NIM-VAB-A) for home use, to replace consumer grade "standard" home router.
The router is working OK, in terms of configuration, but it hangs every few days. NAT translations stops the translations and no WAN access.
The xDSL modem in such state continue to be connected and the Ethernet interfaces still has external ISP IP address.
The ISP vendor also confirms that they see the router connected on their end.
(As I connected with download speed of 100mbit, the modem is connected to the ISP using PTM method and not ATM)
Any idea what can cause to NAT translations stop working. only router's reload solves the problem.
(I didn't find any other way to resume NAT translations)
Reuven
Hello Reuven,
this could be caused by a variety of issues. Can you post your configuration ? Are you using static and pool translations ?
Which OS version are you running ? Could be a bug as well...
Hello Georg,
Thank you for your help!
Initially I was used OS version "isr4300-universalk9.16.02.01"
Then I assumed maybe some bug with this OS and switched to OS recommended by Cisco (marked with star): isr4300-universalk9.03.16.04b.S.155-3.S4b.
The problem didn't disappear unfortunately, but looks like appears with lower frequency.
my key router configuration is as below (excluding DHCP server setup...):
hostname Router
boot-start-marker
boot system flash bootflash:isr4300-universalk9.03.16.04b.S.155-3.S4b.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no logging buffered
no aaa new-model
clock timezone Israel 2 0
ip nbar http-services
subscriber templating
crypto pki trustpoint TP-self-signed-3667045416
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3667045416
 revocation-check none
 rsakeypair TP-self-signed-3667045416
diagnostic bootup level minimal
redundancy
 mode none
controller VDSL 0/1/0
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
 description LAN$ETH-LAN$
 ip address 10.0.0.200 255.255.255.0
 ip nat inside
 ip nbar protocol-discovery
 ip tcp adjust-mss 1452
 media-type rj45
 negotiation auto
interface GigabitEthernet0/0/1
 no ip address
 shutdown
 negotiation auto
interface Ethernet0/1/0
 no ip address
 no negotiation auto
 pppoe enable group global
 pppoe-client dial-pool-number 120
 vrf forwarding Mgmt-intf
 no ip address
 shutdown
 negotiation auto
interface Vlan1
 no ip address
 shutdown
interface Dialer120
 mtu 1492
 ip address negotiated
 ip nat outside
 encapsulation ppp
 load-interval 60
 dialer pool 120
 dialer-group 1
 ppp authentication chap pap callin
 ppp chap hostname username
 ppp chap password 0 Password
 ppp pap sent-username username password 0 Password
ip nat inside source list 1 interface Dialer120 overload
ip forward-protocol nd
no ip ftp passive
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 Dialer120
access-list 1 permit 10.0.0.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
line con 0
 stopbits 1
 speed 115200
line aux 0
 stopbits 1
line vty 0 4
 privilege level 15
 login local
 transport input telnet ssh
 transport output telnet ssh
line vty 5 15
 privilege level 15
 login local
end
Reuven
