NAT rules
asbesi001
Level 2
Level 2
I have a question regarding NAT.
Is it possible to apply two NAT rules, if yes, will it increase CPU utilization, have you applied in real traffic?
My scenario is simple. I have two ISP connections, and I want using nat to route traffic for a particular subnet through first isp, and other subnet through second isp.
For example:
ip nat inside source list 10 interface FastEthernet0/0 overload
ip nat inside source list 20 interface FastEthernet0/1 overload
access-list 10 permit ip host 192.168.10.100 any
access-list 10 deny ip any any
access-list 20 deny ip host 192.168.10.100 any
access-list 20 permit ip 192.168.10.0 0.0.0.255 any
access-list 20 deny ip any any
Hope it is clear!
Brj
Hello.
This won't work, as you need to make routing first.
In your case, I would suggest to read http://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/100658-ios-nat-load-balancing-2isp.html
Instead of load-balance (like on the article) you need to run PBR on inside interface.
Hi Vasilii,
Thnx for the reply!
PBR has a quite big impact on CPU, and it's not my preferred way. Is there any way to achieve this?
-brj.
Hello.
Please share the details of your hardware and link bandwidth, so we could estimate the impact.
Could you please clarify what is the business driver for your case?
