NAT support
matt_heff
Level 2
Level 2
Does the 3750 support NAT? I'm pretty sure the SMI/ipbase image doesn't, but what about the EMI/ipservices image?
Matt
ahmednaas
Level 8
Level 8
I just tried this on a 3560 running the advanced ip services image:
C3560PoE>en
Password:
C3560PoE#conf t
Enter configuration commands, one per line. End with CNTL/Z.
C3560PoE(config)#ip nat ?
% Unrecognized command
So it seems NAT is not supported. Also a search of the "Catalyst 3560 Switch Software Configuration Guide.pdf" did not produce any refrences to configuring NAT.
jcorrale
Level 3
Level 3
Hi Matt,
According to the document below, NAT is not supported on the 3750 switches:
Network Address Translation Catalyst Switch Support Matrix
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a008011c629.shtml
Hope it helps!
Juan
