Nat
Firass.elheilani
Frequent Visitor
Frequent Visitor
Hello everyone,
I have a problem for port 443.
I configured the Nat for port 443:
ip nat inside source static tcp x.x.x.x 443 x.x.x.x extendable
When I reload the router, it loses the configuration (ip nat inside static source tcp x.x.x.x 443 x.x.x.x 443 extendable) even when I don't reload, the router loses the config.
it arrives with the port 443 but not for the other ports.
I made an update of the router, but we have the same problem.
We have changed the router, but we have the same problem too.
Here is the model of the router:
C1111-4P
Version: 16.09.02
Than you
Georg Pauwen
do you have https enabled on the router ? Try and configure:
no ip https secure-server
Thank you for your answer.
It is a router that is in production.
I'm going to restart it tonight and see if it works
Thank you
Curious to know what the result is...
Hello
@Firass.elheilani wrote:
Hello everyone,
So you have multiple static nat translations for the same inside local addressing which are not saved in the running config-correct?
Can you elaborate regards your comments I have highlighted in bold and post the output of the following:?
sh run | in ip nat
sh ip nat translations
sh version | in Con
Kind Regards
Paul
