NAT
M.Sultan
Dynamic NAT
uses a pool of public ip address to perform
NAT
, One single interface can be assigned two IP addresses the first primary and the secondary, if we want to use 5 public ip addresses for
Dynamic NAT
where should we assign them ? while we have one single ISP link  ?
thank you
2 Accepted Solutions
correct, ONE IP assign to ip nat outside interface and other public IP is add to Pool of NAT
interface ethernet 0
 ip address 10.10.10.1 255.255.255.0
 ip nat inside
!--- Defines Ethernet 0 with an IP address and as a NAT inside interface.
interface ethernet 1
 ip address 10.10.20.1 255.255.255.0
 ip nat inside
!--- Defines Ethernet 1 with an IP address and as a NAT inside interface.
interface serial 0
 ip address 172.16.10.64 255.255.255.0
 ip nat outside
!--- Defines serial 0 with an IP address and as a NAT outside interface.
ip nat pool no-overload 172.16.10.1 172.16.10.63 prefix 24
!--- Defines a NAT pool named no-overload with a range of addresses
!--- 172.16.10.1 - 172.16.10.63.
ip nat inside source list 7 pool no-overload !--- Indicates that any packets received on the inside interface that
!--- are permitted by access-list 7 has
!--- the source address translated to an address out of the
!--- NAT pool "no-overload".
access-list 7 permit 10.10.10.0 0.0.0.31 access-list 7 permit 10.10.20.0 0.0.0.31 !--- Access-list 7 permits packets with source addresses ranging from
!--- 10.10.10.0 through 10.10.10.31 and 10.10.20.0 through 10.10.20.31.
 Configure Network Address Translation - Cisco
this link explain all cases need for NAT, one of them is using POOL
7 Replies 7
can you more elaborate
Hello
you create a acces-list for you lan clients and a
NAT pool
for the 5 public ip address
example:
access-list 1 192.168.1.0 0.0.0.255
Ip nat pool PUBLIC 1.1.1.1 1.1.1.5 prefix 29
ip mat inside source list 1 pool PUBLIC overload
sent from iphone:
Kind Regards
Paul
At least i need on of public ip to be assigned into my inside global interface and the rest 4 publics won't need be added to interface ? just add them into the pool ???
Hello
ip nat
NAT
FYI, the public
nat
addressing does NOT need to be assigned to any interface, they just need to be reachable to external users for your site
Kind Regards
Paul
A public IP must be assigned to the inside global interface and the rest four IP including assigned IP should be added to the scope of access list.
Exm: Int 0/0 (1.1.1.1 255.0.0.0)
ip nat pool Public 1.1.1.1 1.1.1.5 prefix 8
am i correct ?
 ip nat inside
 ip nat inside
interface serial 0
 ip nat outside
