NATing on router 2800 series
junaid haroon
I have Router 2800 series Global nating is configured on it.
ip nat inside source list 111 interface Dialer1 overload
access-list 111 deny   ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 111 permit ip 192.168.1.0 0.0.0.255 any
My object is that i want give internet access only for few users ip E.g  IPs addresses from range
192.168.1.0-10 can acess intenet access other all are deny.How i do this with ACL .
no, that won't work as there is no possibility to configure an IP-range in an access-list-entry. That can only be achieved through an object-group.
Another way is to allign the range of permitted PCs on a subnet-border (192.168.1.1-192.168.1.15). Then you can specify that with one line in the ACL:
access-list ext internet_control
  permit ip 192.168.1.0 0.0.0.15 any
  deny ip any any
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
7 Replies 7
You shouldn't use NAT for that. NAT is an addressing-function and not a security-function.
Better place an ACL in the traffic-path to filter the traffic which can be sent towards the internet and let your NAT-config untouched:
object-group network INTERNET-PCS
  range 192.168.1.1 192.168.1.10
ip access-list extended INSIDE-IN
  permit ip 192.168.0.0 0.0.0.255  192.168.0.0 0.0.0.255
  permit ip object-group INTERNET-PCS any
  deny ip any any
int fa 0/0
  description inside interface
  ip access-group INSIDE-IN in
Leo Laohoo
Duplicate posts.
Is following one is correct.
int fa 0/0
ip access-group internal_control in
access-list internet_control permit IP 192.168.0.-10 0.0.0.255
access-list internet_control deny IP any any.
No the syntax is incorrect, you'll have to use the object group feature like Karsten showed you or if it is not available on your IOS you'll have to use multiple entries in your ACL to match the hosts .1-.10
Alain
  deny ip any any
I want to study object-group ACLs in detail can you please refer a any video tutorial or any detailed guide.
http://www.cisco.com/en/US/docs/ios-xml/ios/sec_data_acl/configuration/12-4t/sec-object-group-acl.html
Alain
