NATTED IP
lakhwaraa
Level 3
Level 3
I (192.168.23.1)  have to connect to my partner office (192.168.70.30) on an MPLS connection. The connection is established and ping is ok. Now My partner asks me that (Your Source/Natted/Tunnel IP address will be  10.15.17.10 /32 (Route Base VPN)). what is my natted Ip and how to configure it????. any body help
Hi @lakhwaraa
This means instead of using the previous IP address to access your partner now you will use  10.15.17.10 /32
the only way is enable NAT in LO (which manually you must assign 10.15.17.10/32)
LO will work as INside and OUTside for NAT in same time
you need also PBR.
but all above stop in one case I dont figure out how to solve it which is PBR with set ip next-hop LO is not work.
Hello
Can you elaborate on your current network setup, maybe share a topology diagram so we can obtain a clearer understanding of how you are connecting or want to connect to your partners office.
Kind Regards
Paul
