NBAR on Tunnel Interface on ASR1001
Ilya Geraskin
Hello all,
I'm trying to implement service policy on our ipsec tunnels on ASR1001. Version: asr1001-universalk9.03.13.01.S.154-3.S1-ext.bin
Here is the typical Tunnel configuration:
interface Tunnel100
 ip address 172.x.x.x 255.255.255.252
 ip mtu 1450
 ip access-group ACL_IN in
 ip access-group ACL_OUT out
 ip policy route-map ForwardIP
 ip ospf network point-to-point
 ip ospf mtu-ignore
 ip ospf cost 40
 qos pre-classify
 tunnel source ZZ.ZZ.ZZ.ZZ
 tunnel mode ipip
 tunnel destination YY.YY.YY.YY
 tunnel protection ipsec profile IPSec-AES
 service-policy input Tunnel_IN
When I try to add an output service-policy on that interface, I get an error:
(nbar): (err): NBAR is not supported on  Tunnel10042
If I try to enable ip nbar protocol-discovery, I get an error:
% NBAR Error: Can not enable Protocol-discovery NBAR is not supported on this interface
Is it possible to use NBAR on that interface?
Collin Clark
NBAR is not supported on the following logical interfaces:
  • Dialer interfaces
  • Dynamic tunnels such as Dynamic Virtual Tunnel Interface (DVTI)
  • Fast Etherchannels
  • IPv6 tunnels that terminate on the device
  • MPLS
  • Overlay Transport Virtualization (OTV) overlay interfaces
Is there any workaround for it?
Configure NBAR on the downstream physical interface
Will this policy work on IPSEC tunnels?
I thought
qos pre-classify
works only when you implement qos on tunnel interface.
With NBAR enabled on physical interface the tunnel is still not configurable with NBAR policies
